Tricometric Indicator Support
db5
Post by db5 »
From 1965. I'll bet if JPG goes through his miscellaneous engineering tools he has one of these somewhere.
Tricometric Bracket.JPG (230.58 KiB) Viewed 5218 times
robinson46176
Re: Tricometric Indicator Support
Post by robinson46176 »
I have either 2 or 3 of those depending on which end you count from... :p
I think someone drew the support upside down and on the wrong side of the bracket. :eek:
I used to have one similar, but it had 5 threaded ends.
garys
Post by garys »
It looks like it should do a good job, but I'm not sure what job that is.
wa2crk
Post by wa2crk »
I had one of those. Got it from my uncle Rube G. It worked great.
I believe it's original design intention was to measure wind shield wiper blades of a specific brand. :rolleyes:
Ed in Tampa
Post by Ed in Tampa »
I have one of those, set up, my Shopsmith with it. Worked perfectly.
FYI do not believe people that say you can not free hand cut perfect circles on a Shopsmith setup in table saw mode. :cool:
edma194
Post by edma194 »
You can threads the posts with a standard die but you need a special tap to the cut the threads in the ambihelical nuts.
