Nick Engler's Workshop Companion
Chad
Post by Chad »
For those who don't know who Nick is:
Check out Nick Engler's Workshop Companion youtube channel and website.
Workshop Companion youtube channel:
https://www.youtube.com/channel/UCk480B ... hMfkBjhDpQ
Nick Engler's Workshop Companion website:
http://www.workshopcompanion.com/index.htm
I'm sure Nick would greatly appreciate your support!
Thanks
eartigas
Re: Nick Engler's Workshop Companion youtube channel & website
Post by eartigas »
I am already enjoying these videos. I hope he keeps posting.
Chad
Post by Chad »
So do I.
Chad Nevels
    1963 Shopsmith Mark V "Goldie" 1-1/8 hp Serial # 379185
    1980 Shopsmith Mark V 500
    1994 Shopsmith Mark V 510
    1994 OKUMA LB15 II OSP7000
    2017 OKUMA LB3000 EXII SPACE TURN MY OSP P300LA
Chad
Five Quick Tips for Gluing
Post by Chad »
Watch it here: https://www.youtube.com/watch?v=Wmw5ray ... L&index=35
Nick shares five time-tested workshop hacks to help make your gluing operations easier, your glue joints stronger, and your glued-up assemblies more precise.
Nick Engler's Workshop Companion youtube channel:
selfes121
Re: Five Quick Tips for Gluing
Post by selfes121 »
pcd7326 wrote:[youtube]https://www.youtube.com/watch?v=Wmw5rayNIV4[/youtube]
What a great video. Maybe you can give some advice on which glue is better to bond wooden parts? I am interested in fast-drying and non-toxic glues as I'll make all kinds of wooden toys for my children.
Chad
Best Adhesives for Chair Repair. Not just for chair repair.
Post by Chad »
Ask and you shall receive.
Not just for chair repair, but for many applications. Nick strength tests most adhesives that are popular (and not so popular) and available on the market today:
Watch it here: https://www.youtube.com/watch?v=mO03Ykq ... L&index=34
Restoring a chair presents special problems. The wooden surfaces are covered with old glue and the joints are loose, making it difficult to create a strong bond. And not only must you reassemble the chair parts, the adhesive you use must fill the voids in the loose joints. We test several readily-available glues for both their strength and gap-filling properties. We also investigate several materials made just for chair repair that claim to secure the joints either by filling the gaps or swelling the wood to fit.
algale
Post by algale »
No surprise that the epoxy had the highest strength.
What surprised me was the relatively low strength of the hide glue -- especially considering that antique furniture, including, chairs were put together with hide glue and stayed tight for decades or even hundreds of years.
But I have a hypothesis. As I understand it, hide glue strength is very dependent on two factors: gram strength and using the proper amount of water. I assume Nick knows how to mix hide glue properly. I just wish he had told us the gram strength. I'm guessing this was not a high gram strength hide glue.
Hope Shipwright, who was our resident hide glue evangelist checks this out and offer his opinion.
Chad
All of Nick's video's from Workshop Companion thus far
Post by Chad »
In case you haven't visited Nick Engler's Workshop Companion youtube channel or website yet. Here are the rest of Nick's videos from his Workshop Companion youtube channel. Enjoy!
Router Plane Jig
Watch it here: https://www.youtube.com/watch?v=BS5PGsg ... L&index=29
The router Plane is a woodworking jig used to make one surface flush with another, it can be built with materials in the shop and used for a number of things including cabinetry, counter tops, and screw heads.
Scrapwood Rolling Pin
Watch it here: https://www.youtube.com/watch?v=SkSRPM_ ... L&index=30
We turn an elegant rolling pin from scraps of hardwood, softwood, and plywood. An awesome turning project that will cost you nothing to make.
Herringbone cutting board
Watch it here: https://www.youtube.com/watch?v=ciA5S81 ... L&index=31
A time lapsed video of Nick making a Herringbone cutting board. For those that want more description on making a herringbone cutting board we'll be posting a video in the future called "Herringbone cutting board techniques so make sure you subscribe!! We're giving away the cutting board made in this video to a randomly selected person that shared the video on Facebook. Like and follow our Facebook page @workshopcompanion.
5 Expert Table Saw Tips
Watch it here: https://www.youtube.com/watch?v=ALkltNQ ... L&index=32
Master craftsman and woodworking author Nick Engler reveals five professional secrets to help you get better results when using your table saw. Learn how to set the blade and miter gauge angles with precision, line up for a perfect cut, keep the wood from pinching the blade, even make a super-smooth cut in plastic.
5 More Expert Table Saw Tips
Watch it here: https://www.youtube.com/watch?v=9OLVceN ... L&index=33
lili90
Post by lili90 »
Good video
Chad
Scrapers and Scraping
Post by Chad »
Watch it here: https://www.youtube.com/watch?v=ay6kXarG7oc
Nick Engler shows two ways to sharpen scrapers -- the traditional method using files and burnishers, and the "easy" method using files only. He also explains how to sharpen curved scrapers, using a drill bit to create a sharp edge. Finally, he demonstrates how to scrape wood, achieving in just a few seconds a smooth surface equivalent of sanding with 120# or 150# sandpaper.
