8" dado set?
djg
8" dado set?
Post by djg »
I have a Mark V model 500. Shopsmith only sells a 6" dado set.
Is it safe to use an 8" dado set on my Shopsmith?
Thanks.
mountainbreeze
Re: 8" dado set?
Post by mountainbreeze »
The only dado set I have ever used on my Shopsmith is an 8" set. Works fine.
garys
Re: 8" dado set?
Post by garys »
I have had both a 6" and an 8" dado that I've used on my Shopsmith. I don't know of any reason it isn't safe.
djg
Re: 8" dado set?
Post by djg »
Thanks much!
Re: 8" dado set?
You will want to make your own table insert if you plan to take advantage of the larger blade size. The shopsmith version is designed for the smaller diameter blades.
djg
Re: 8" dado set?
Post by djg »
Hadn't thought of that. Thanks!
Chad
Why don't we all use 10-inch dado sets on our 10-inch saws?
Post by Chad »
download (1).jpg (12.17 KiB) Viewed 4282 times
Watch it here: https://www.youtube.com/watch?v=ioyobsgaYUA
James Hamilton (Stumpy Nubs) gives some great information in this video. It's only 3:32 long. Well worth your time.
Should you use a 6, an 8 or a 10-inch set?
When you use this link to visit our sponsor, you support us►
Ridge Carbide Dado Sets (Use coupon code SNWJ10): https://goo.gl/z8TP0k
Video about setting up a Dado set: https://www.youtube.com/watch?v=KPYXU...
What to look for in a good dado set: https://www.youtube.com/watch?v=Ex4Ug...
Subscribe (free) to Stumpy Nubs Woodworking Journal e-Magazine► http://www.stumpynubs.com/subscribe.html
Follow us on social media►
Instagram: https://www.instagram.com/stumpynubs/
Twitter: https://twitter.com/StumpyNubs
Facebook: https://www.facebook.com/Stumpy-Nubs-...
Chad Nevels
    1963 Shopsmith Mark V "Goldie" 1-1/8 hp Serial # 379185
    1980 Shopsmith Mark V 500
    1994 Shopsmith Mark V 510
    1994 OKUMA LB15 II OSP7000
    2017 OKUMA LB3000 EXII SPACE TURN MY OSP P300LA
StevenAyres
Re: 8" dado set?
Post by StevenAyres »
It's apparent that Shopsmith chose blade diameters primarily in consideration of available torque. Older models with less power are sized for 9" cutting blades, younger for 10". The much larger cutting face of a dado takes a lot more torque than a cutting blade, so you'll always use dado sets that are smaller than your cutting blades.
Re: 8" dado set?
StevenAyres wrote: Fri Nov 13, 2020 10:43 am It's apparent that Shopsmith chose blade diameters primarily in consideration of available torque. Older models with less power are sized for 9" cutting blades, younger for 10". The much larger cutting face of a dado takes a lot more torque than a cutting blade, so you'll always use dado sets that are smaller than your cutting blades.
This is indeed the case for conventional table saws. But when it comes to blade compatibility, a Shopsmith has a distinct advantage over conventional saws. The variable-speed Reeves drive in the headstock is quite literally a variable-speed transmission. So if you reduce the blade speed, you also increase the available blade torque, in direct proportion.
If you want or need to use a larger-diameter blade, or to make a heavier rip cut, you can crank the speed down. Which unless a drive belt slips, is synonomous with cranking the blade torque up. That’s not exactly a substitute for a more powerful motor, though. If you have to reduce the blade speed, you will have to reduce your feed rate commensurately. But an 8” dado stack, running at 75% of the rpm of a 6” stack, will have the same tooth velocity. And be capable of the same feed rate, everything else being equal.
I’d argue that the extra width of a dado stack is the reason that the “dado” setting on a Shopsmith speed dial is a lower speed than the “saw-joint” setting. The smaller diameter does reduce the blade torque requirement. But in the case of a wide stack, not by enough.
I consider the settings on the Shopsmith speed dial to be just approximations of the ideal speed. You can vary the speed as needed to best match the operation at hand. Which is also quite useful for reducing “burning” when cutting wood. I cut quite a bit of cherry, which burns easily. But if I get burning at the “saw-joint” setting, and everything is sharp, clean, and aligned, I just crank down the speed until it goes away. End of problem.
dms8667
Re: 8" dado set?
Post by dms8667 »
Nice summary!
