I am trying to make adjustments to the high-speed setting on my SS Mark V and discovered this inconsistency
Many articles say to: “Use a small screwdriver to hold the set screw, then loosen the jam nut. If the high speed stop engaged before the drive belt was near the edge of the motor pulley, turn the set screw COUNTERCLOCKWISE and, at the same time, turn the worm shaft CLOCKWISE until the belt is between 1/8" and 1/16" from the outer edge of the pulley. Note the use of pads on the pliers-this is to protect the worm shaft. This is the Shopsmith recommended procedure.”
There seems to have been a change in the manufacturing of this part. The aforementioned set screw does not accept the head of a screwdriver as described in the article but rather a 1/8” Allen wrench.
New Speed Control's jam nut set screw accommodates 1/8" Allen wrench--not slot for screwdriver
ALarryAaron
Re: New Speed Control's jam nut set screw accommodates 1/8" Allen wrench--not slot for screwdriver
Am I to conclude that you are asking if you can use an allen wrench rather that a screwdriver? I would say "Go for it". What damage could you possibly cause. It seems obvious to me that the vintage of the speed control; and that of the instructions are not the same.ALarryAaron wrote: Wed Dec 16, 2020 9:19 am I am trying to make adjustments to the high-speed setting on my SS Mark V and discovered this inconsistency
ALarryAaron
Actually, I wasn't asking about whether to go for it or not; I was letting others know that the published info is out of date compared to latest manufactured part.
Thanks.
Thanks.
I am curious what the creation date of the 'procedure' is you are referring to.
I am also curious re the source of that 'procedure'.
I am not aware of any SS publication regarding setting the high speed stop. Nick's stuff is NOT a SS publication per se.
