Powerpro rattle -- quill issue?
paulrussell
Post by paulrussell »
Hello, a few years back I installed the PowerPro. When I did so I was not able to get it as quiet as in the videos. I should have paid better attention.
Recently I decided the wedge locks needed some attention and while I was at it I revisited the high-speed rattle. After much time spent with belt tensions and eccentric bushing adjustment I decided to pull the quill. The rattle was gone.
Investigating the quill, the issue appears to be too much play between the rear (smaller) bearing and the quill body. Wiggling the spline shaft visibly moves the entire bearing, including the outer race. No such play in the larger front bearing. My digital caliper puts the rear bearing (specified to be 35mm) at 34.98mm
I could try a new bearing but I fear the issue is the bore of the quill itself. Sadly, I am very much past warranty.
Was there a known bad batch of quill bodies? Is there a good way to solidly seat the bearing despite this issue? Or, am I likely whistling up the wrong tree?
Re: Powerpro rattle -- quill issue?
I would contact SS. If it is in fact a manufacturing defect in the quill body, the warranty does not apply. SS should make it right.
paulrussell
After a half hour wait on the phone I gave up and sent an email. Fingers crossed.
I've ordered a bearing (they are cheap) in case my calipers are off and I indeed have an undersized bearing.
Worst case is the sleeve bearing seat is oversized and Shopsmith won't replace. In that case I'll probably give Loctite 660 a try.
