I was into the finish sanding when I realized that I hadn't drilled holes for the plugs that would hide the screws holding the sides to the top and bottom. No problem, just get the 3/8" Forstner bit out and drill six holes. Did the bottom just fine. In doing the top, I noticed that some pilot holes drilled for the temporary assembly were in the wrong place. Again no problem, they are small and a little filler would hide them. However, in thinking about this while drilling, I promptly drilled the plug holes in the wrong pilot holes. There went the top. After some time I thought I could have salvaged the piece by adding decorative plugs as I did on the cutting boards, but by then the top had met with an "incident" and was no longer usable.
All this while my mind had already moved on to the next projects. These were inspired by plans in a recent Canadian WW magazine for some serving trays, and a desire to try turning. The recent post about coffee mugs and an email from Rockler advertising ice cream scoop kits reminded me of my bottle stoppers, again.
After sharpening my chisels, I cut a couple of cedar practice blanks and proceeded to turn. Based on my results, it will take a lot of practice and I may not finish any stoppers in time for the craft show on December 7th.
As for the trays, I was hoping to use some of my scraps but most are too small so I will have to cut into some real wood if I want to proceed with these.
Oh well, it's a new week so maybe I can have another fresh start.
Have a Safe and Fun week!
John
