Stay with 500 table or upgrade to 510/520 table for dedicated drill press?
number3456
Post by number3456 »
Greetings!
I bought a 1979 500 basket case that I will go through and clean up. I plan to use it as dedicated drill press and get rid of the table top cheapie drill press I currently have. I will replace the single bearing quill with a 2 bearing quill from the 510 I upgraded to the power pro headstock.
Question is can anyone think of a reason I should look for a 510 table to replace the 500 table since it’s only going to used as a drill press? I don’t want to spend the money for a larger table unless folks can think of a reason to add a larger table.
Thanks
Tim
520 now upgraded to Mark 7, 520 "shorty", 500 converted to a dedicated drill press.
2 - bandsaws, jig saw, belt sander, strip sander, 4" Jointer, planer, air compressor.
ClearVue dust collection system.
Re: Stay with 500 table or upgrade to 510/520 table for dedicated drill press?
If you need a larger table surface, a piece of 3/4" plywood will work. I think you need a 'topper' for the table anyway. However the rip fence comes in handy at times. Stay flexible!!! A shaper insert would be desirable.
number3456
Thanks!
