Sanding Disk / Plates
Thomschuck
Post by Thomschuck »
Fellow Shopsmith Genius’s,
Before I ruin my arm what is the best way to remove OLD adhesive from the sanding plates. The first one was easy. The second plate has had paper applied on top of other paper. I got the main paper rounds removed but have a ton of old adhesive left behind. Plate one I used paint thinner and a putty knife with rounded corners. I finished it off with 80 grit on my orbital. Looks like new. Anyone know the easy way for the fix? Thanks for every consideration.
Thom Schuck
Portland, Oregon And The SUN is out!
Thom Schuck
SS Model 5 500 Completely Restored
SS Bandsaw Completely Restored
SS Jointer Completly Restored
SS Biscuit Cutter
Rikon Low Speed Grinder W/Wolverine jig
Kreg Tool TrackHorse X 2 + Kreg Tool Project Center with 35 Kreg Tool Clamps
11 Systematic Blades of every configuration
Bosch/Mikita handheld power tools plus every hand tool in the book.
Ulmia Chisel sets X 3
Permobile Custom RideForward Powerchair
Complete set of registered # NASA X-15 Custom Tools W/Ownership certificate
edma194
Re: Sanding Disk / Plates
Post by edma194 »
Mount it, spin it at low speed, use soft scrapers and scotch brite pads.
edma194
Post by edma194 »
edma194 wrote: Sat Mar 27, 2021 6:54 pm Mount it, spin it at low speed, use soft scrapers and scotch brite pads.
ETA: Soften it up first with solvent, but don't leave it dripping wet.
