Finally managed to register!
Wick1
Post by Wick1 »
I must have made about a dozen attempts to register on the forum. I usually failed because the bit where you have to retype the security code was extraordinarily difficult to read (U's looking like V's, 6's appearing as 8's and vice versa) and I kept getting it wrong. After several successive attempts I would be told that I had tried too many times and should have another go later. I also tried to contact a moderator for help but unless you are registered, it seems that this is not possible. So Catch-22! Anyway, I'm here now.
Re: Finally managed to register!
Wick1,
Welcome to the Shopsmith Forum. Sorry you had so much trouble getting registered. I am guessing you have already been looking around at the site. There is a lot of good information available here and if you need any help just ask.
