Now for my problem.
I own a MK model 500 SS. There is a lock rod #504233 and wedge locks, #504235 LH & #504233 RH used to lock the work table to the way tubes. The lock rod goes through a handle in front. There is some mention that the lock rod is sold ony as part of an assembly. That is in my manual which is a 1986 vintage manual.
My lock rod seems to be jammed into the wedge locks and the lock rod actually broke in my hand.
The handle is pinned through the lock rod. SS doesn't carry the lock rod but the do sell the right hand and left hand wedge locks.That doesn't make sense to me. Has anyone else had this issue?
I have contacted SS through the website but I do not expect any response. Apparently it has never been offered alone. I would buy the whole assembly but is it not offered that way either.
What do you think about using a turnbuckle setup if they have one in 3/8" rod. I need the LH & RH threaded rods to make it work. Getting the rod to tie into the wedge locks may be the bigger problem.
Any other suggestions??
Thanks in advance.
