I have the SS planer and have had great results on Maple, Paduk, Walnut etc.
I usually just leave the headstock on S or T and the unit feed rate on 10 figuring fast blade spin and slow feed rate will give me the best results.
But, I have a question - on the unit, it says that for most woods and cut depths, 10 is the maximum speed of feed (using T on the motor control) but for some hard woods and/or deeper cuts, it states that 5 or 6 is the maximum speed.
So far, so good but, I noticed that 10 is the slowest feed rate and 1 is the fastest rate - so, aren't these instructions wrong? Shouldn't the max rate on a wide or deep or hardwood cut be slower than the lighter cuts? Are the markings on the speed control (on the unit, not the SS head) reversed?
Hmm - wonder how mine got reversed - 10 is definitely a lot slower than 1. Oh well, so long as I know it's reversed, now the directions make a lot more sense.
SS MV 520, bandsaw, jointer, planer, belt sander, mortise unit, biscut jointer, speed reducer, tool rest upgrade, sliding cross cut table, DC3300
