505644 Jig Saw blades
miken
Post by miken »
Hi guys, I bought a used 505644 jig saw and was looking for a recommendation on some aftermarket blades. Yes, i have become a full-on Shopsmith SPT addict. :D Can't stop myself from buying stuff I probably don't need. Preaching to the choir on this forum i suppose. I was warned. ;)
I asked if the puffer works and he said it does, but doesn't put out much air. Is that normal?
Any advise on things to look at when I receive it. I know about making sure it has oil in it, and I will need too add that as he removed the oil for shipping. What type of oil is best.
I plan to search for a manual, but really prefer the advice and experience of this forum.
Thanks, Mike
Atlas 7B Metal Shaper
Re: 504644 Jig Saw blades
#10 machine oil/air compressor oil.
"Puffer" is weak - some oil on the leather piston seal will help.
miken
Post by miken »
JPG wrote: Sun Jun 20, 2021 9:39 pm #10 machine oil/air compressor oil.
Thanks JPG, it has a Shopsmith badge instead of the Magna M. Any differences aside from the branding?
Mike -
miken wrote: Sun Jun 20, 2021 9:51 pm
Mike -
No. Magna = Shopsmith. Shopsmith = Magna. The original Shopsmith from 1947 was made by Magna Engineering. There have been minor changes over the years but they are the same machine.
Mike907
Re: 505644 Jig Saw blades
Post by Mike907 »
Scott Markwood's last four videos are on the jigsaw. In the first one, I believe he says to use pinless scrollsaw blades.
https://www.youtube.com/c/MyGrowthRings/videos
Or pinned ones with the pins removed.
garys
Post by garys »
Shopsmith has some suggestions for blades. They are likely commonly available at your local stores.
https://www.shopsmith.com/mediawiki/index.php/Jigsaw
miken
Post by miken »
garys wrote: Mon Jun 21, 2021 10:03 am Shopsmith has some suggestions for blades. They are likely commonly available at your local stores.
Thanks, interesting Shopsmith recommends Marvel Mystery Oil on that link site. I thought that was a detergent and generally frowned upon.
Mike -
Mike,
John already said it but here is a little more information. The Jig Saw Model 610 (later 505644) came out in 1954 after the Mark 5. As with all the Add-a-Tools (Later referred to as SPT's) they were Magna tools not Shopsmith and had the M logo on the main housing cover. Shopsmith was the name given to the first 5 in 1 tools the Shopsmith Model 10E/10ER followed later By the Shopsmith Mark 5 in 1954. After Shopsmith Inc. formed in 1972 and brought back the Mark 5 and the SPT's all tools were Shopsmith but it was several years before the SPT's all had the Shopsmith Logo on them. Early Jig Saws were painted to match the Mark 5 of the time periods starting with Greenies then Goldies followed by gray. Very little changed over the years for the Jig Saw. The logo on the cover plate, going from straight mounting posts to eccentric ones and a late change to the table tilt lock using an Allen Cap Screw and washer.
As for blades it has already been said almost any straight end will work just avoid reverse tooth blades which cut in both the up and down strokes. They are good for use on the Scroll Saw but not the Jig Saw.
miken
Post by miken »
Thanks for the info guys. I watched one of the my growth rings videos, and will watch the others (thanks Mike907). Russ, appreciate the history. I am hoping I got lucky and it's in good working condition like the belt sander I bought. I don't mind tearing it apart, cleaning, lubricating it, etc. but if parts are too worn or damaged, well buyer beware I guess.
Thanks again, Mike -
