Why do it this way?
Why do it this way?
I recently viewed on "Chip's Wood Shop" a video on using a shopsmith to tap threads. Great idea. But why, unless I already had it, do I need an adapter for a SS router bit when I already have one of these? And so do you. No set up required.
- Tap Threads.JPG (28.53 KiB) Viewed 1662 times
- P1140319.JPG (36.25 KiB) Viewed 1662 times
Re: Why do it this way?
Sanding disk works fine also. Just remember that you left it up there.
I second a sanding disk. That's what I used when I threaded a bunch of 80/20 aluminum extrusion used in building my first CNC.
Roy
Home designed and built CNC router, another CNC router
desktop size, Avid 5x10 Pro CNC w/ATC, CNCed G0704 milling machine
Laser engraver
Way too much other stuff and not enough space
Laser engraver
Nix on the crescent wrench(if it slips it may mar the shaft).
Sanding disk will work fine BTDT.
Leaving wrench is worse than leaving the chuck key attached!!!!
- BuckeyeDennis
Well then, no more bright ideas for you! Unless (until) I get another one. Spanner is out, Disk is in.
