Miter Gauge Extension Table
Syzygy99
Post by Syzygy99 »
Will the old Miter Gauge Extension Table fit on the PowerPro table?
Re: Miter Gauge Extension Table
no.
only works with M5 and V500 tables.
The current version CAN be adjusted to work with the older (cast in rail) tables etc.
Syzygy99
Post by Syzygy99 »
Thanks JPG. Do you know the catalog number of it? [The current version]
WHY if you have a powerpro? It is neither a M5 or a V500.
Sorry I was on vacation the last few days but wanted to make sure what was being referred to. Sygyzy99 you asked
As JPG said the Miter Gauge Extension Table was made only for the original table system of the Mark 5 and Mark V 500. PowerPro is the DVR motor for the Mark 7 and is a upgrade available for any Mark 5/V. The Mark 7 uses the same table system as the Mark V 520 except the table posts are reversible. Is that what you are referring to as a PowerPro Table? The Miter Gauge Extension Table has come in two versions and the change occurred in the latch that holds the extension to the main table. It was changed when the original Mark 5 table went from a cast on to a bolt on fence rail. It cannot clamp onto either the Mark V 510/505 or the Mark V 520 and Mark 7 tables. The Miter Gauge Extension Table is no longer available.
All SPT's & 2 Power Stations
