Blade guard spacer
Blade guard spacer
My table saw blade guard (lower) had a thin cheap feeling aluminium spacer at the bottom I can bend it with my fingers can this be right? The guard looks like a 505628
Re: Blade guard spacer
The picture below is the spacer you are referring to for the Lower Saw Blade Guard 505628. It is made of aluminum and very flexible. It is to give extra space in the lower guard for using a dado or other wide cutters like the molder head.
_
_
All SPT's & 2 Power Stations
I guess flexible is a good way of putting it lolchapmanruss wrote: ↑Tue Sep 07, 2021 11:51 am The picture below is the spacer you are referring to for the Lower Saw Blade Guard 505628. It is made of aluminum and very flexible. It is to give extra space in the lower guard for using a dado or other wide cutters like the molder head.
_
