Old saw table on newer carriage?
shackman66
Post by shackman66 »
I bought a Greenie for a second SS I intend on shortening the tubes by a third to dedicate it to drill press/drive 11" band saw. It had the original saw table complete but is missing the carriage. I have an opportunity to pick up a newer carriage (has a wheel for table lift) for a fair price but some of what I've read has me concerned they won't work together. Anybody know for sure?
MK5 344440 - 1956, MK5 100952 - 1981, Magna Model 610, Magna Model 620, Magna Model 630
algale
Re: Old saw table on newer carriage?
Post by algale »
Won't work.
The mounting tubes center to center spacing is greater on the newer tables and carriage.
edma194
Post by edma194 »
Get a Model 500 carriage instead. As a drill press it won't be a adjusting table height anyway, it will move the table forward and back under the drill press. A hand wheel doesn't have much of an advantage there.
edma194 wrote: Wed Sep 15, 2021 1:56 pm Get a Model 500 carriage instead. As a drill press it won't be a adjusting table height anyway, it will move the table forward and back under the drill press. A hand wheel doesn't have much of an advantage there.
Ignoring the move the handle requirement.
edma194
Post by edma194 »
JPG wrote: Wed Sep 15, 2021 4:10 pm Ignoring the move the handle requirement.
You mean moving it to the other side? That one is easy. The lock takes a little bit of work.
No I was referring to the table getting in the way of the lever and the lever needing to be moved radially on the quill shaft away from the table.
shackman66
Thanks all. Moved on to another problem.....
edma194
Post by edma194 »
JPG wrote: Wed Sep 15, 2021 4:38 pm No I was referring to the table getting in the way of the lever and the lever needing to be moved radially on the quill shaft away from the table.
If you move the handle to other side of the table it's not an issue unless you are using the fence, and that isn't much of an issue anyway, I rarely do more than make minor adjustments to the table position so with the handle straight up there's enough movement available.
???? Straight up is when the table gets in the way???
