Goldie Coupler
bondoboat
Goldie Coupler
Post by bondoboat »
Which coupler is needed for a 1963 Goldie? The part indicated in the other thread says it is for 1985 and later models. Thanks.....BB
beeg
Post by beeg »
From the SS site. "The Coupler Kit is standard equipment with all MARK V's manufactured after April, 1985. "
Coupler For Accessories (spt)
Pn 503574 Is The Coupler Only. Mk V & Accessory "must" Have Hubs To Use.
Pn 555124 Is A "kit" Containing A{coupler}; B{hub For Mk V}; And, C{hub For Accessory(spt)}.
These Parts Are Interchangable With Similar Parts Of Previous Designs. Some Are Open On Both Ends, Some One End Only; Some Are Longer Than Others. Coupler Is Also Compatible With Power Station Spindle.
The Spt End Has 5 Grooves, The Mk V End Has 4 Grooves.
The "kit" Was Included With SS Mk V After April 1985 As Std Equipment.
a1gutterman
Post by a1gutterman »
bondoboat wrote:Which coupler is needed for a 1963 Goldie? The part indicated in the other thread says it is for 1985 and later models. Thanks.....BB
What the others are trying to tell you, is there is only one power coupler; it will work on all Mark V's. It was knot included as standard equipment until 1985. When you buy a Mark V new, you do knot need the coupler, unless you also buy an SPT or two. That is why they did knot include it as standard equipment before 1985.
Tim
Coupler
See What 3 Hours Earlier Does For Clarity!!!!! :D :D :D :D
bondoboat
Post by bondoboat »
Thanks for the responses, now I got it. BB
