Memory failing me.....
I want to look up some parts but I can't recall the right name for them???
You drill a hole and this cylinder with a threaded hole goes in it. Can't recall what they are called, someone must remember???
Re: Memory failing me.....
Don't know if it has its own unique name but is it a nut for a bed bolt?
https://www.leevalley.com/en-us/shop/ha ... em=05G1701
rogersk
Post by rogersk »
reible wrote: Sun Dec 05, 2021 2:56 pm I want to look up some parts but I can't recall the right name for them???
I think you're looking for a barrel nut?
edma194
Post by edma194 »
I second 'barrel nut'. Readily available: https://www.lowes.com/pd/Hillman-20-x-5 ... ut/3012559
rogersk
Post by rogersk »
McMaster-Carr calls them "dowell nuts", where Lowes calls them "barrel nuts". McMaster-Carr shows something different for "barrel nuts". Weird. :confused:
Thank you one and all. With so many names you would think I would have remember at least one of them??
edma194
Post by edma194 »
I never noticed 'dowel nut' being used before. Searches find them under either name. They are the critical component if you want to make your own Jorgensen style handscrew wood clamps.
bainin
Post by bainin »
Doesnt look exactly like your drawing-
https://en.wikipedia.org/wiki/Barrel_nut
AKA steel cross dowel, or dowel nut
Some folks have been known to make them(often).
viewtopic.php?f=7&t=24463&hilit=whatsit
viewtopic.php?p=177231#p177231
