SCARY!!! How to Safely Route Large Profiles on Small Wooden Circles
Chad
Post by Chad »
SHOP NOTES:
Continuing on the build of the hurricane candle bases, today I'm routing the edge profile with a rather large bit, considering the size of these discs. There's also a little lesson about router slippage!
🟢 Please consider joining the 100+ other channel members in supporting the channel and get access to perks: https://www.youtube.com/c/MyGrowthRings/featured
💡 Here's an idea: If you aren't ready or able to join the channel, you can always support the channel by watching, clicking the thumbs-up, commenting, sharing, and by clicking through the provided links whenever you are shopping on Amazon or eBay. You don't even need to purchase the items these links lead to, but by going through these links they'll reward us with a small "finders fee". Thanks in advance for the support!
🟢 I've created an Amazon list of many of the tools that I have found to be indispensable in my shop. http://a.co/0GLhuR2 You may have to click the "Filter" link to show the items in the list. I suggest sorting them by priority.
To answer questions about the tapes I used, see this:
🟢 SpecTape is my favorite temporary double-sided tape: https://amzn.to/3uHEtPw
🟢 Since I mentioned temporary bonds, if you are curious what I use for stronger bonds with double-sided tape, SpeedTape from FastCap is my favorite: https://amzn.to/3a4bLjS
🟢 Finally, for truly permanent bonds with double-sided tape, there's no beating 3M's VHB tape. The version I reach for most is thin and transparent and is permanent even when used outdoors. It's the same that the automotive industry uses to attach the plastic, rubber, and chrome trim onto cars! https://amzn.to/3dcE1Ty Here's a link to Jimmy DiResta, who does a great job showing how he uses VHB tape: https://youtu.be/RxYJ5fDmwjY
🟢 My favorite 9" long T-handle "Shopsmith Toolbox" 5/32" Hex Wrench: https://amzn.to/3sm3NcJ
Visit http://www.MyGrowthRings.com
Follow on Instagram @MyGrowthRings
I also blog at http://www.tool-hunter.com/shopsmith-posts and http://shopsmith-tool-hunter.blogspot.com/
A few viewers have requested I provide affiliate links to help them find the products I use and as a way of supporting the channel through commission. For example, as an Amazon Associate, I earn from qualifying purchases made through the links I provide. If you purchase a product or service through these links, there is NO additional charge to you. I always recommend shopping around for a better price. Thank you for supporting My Growth Rings!
#CandleBase #TableProfile #LargeRouterBit
Chad
Drilling "Tippy" Wood Parts: A Safe, Simple Drill Press Fixture
Post by Chad »
SHOP NOTES:
Continuing on the build of the hurricane candle bases, today I'm laying out and drilling for three wooden "feet", directly over a large router profile, which is creating a rather "tippy" foundation.
Here are links to a few of the products I used or discussed in this video:
🟢 A nice set of Imperial (Inches) Brad Point drill bit set: https://amzn.to/3stpdFY
🟢 The same Brad Point drill bit set as above, but in Metric: https://amzn.to/3AUO9cC
🟢🟢🟢 NOTE: The set I am using is also from Fisch, but is a HSS set, which is much more expansive. I suggest purchasing the Chrome Vanadium set just to have a complete set on hand, but then fill in with induvial HSS bits as needed: https://amzn.to/37R452L
#CandleBase #DrillPressFixture
Chad
The LOST Episode! STUMPED? Q&A: Safely Routing Large Profiles on Small Wooden Circles
Post by Chad »
*To view this video you must be a My Growth Rings youtube channel member.*
For more information, please visit: https://www.youtube.com/c/MyGrowthRings/featured
Exclusive Underwriter gives you access to STUMPED Q&A videos
Access to the video Library of Questions, Comments, & Cheap-Shots from all past videos. All for about $2.00 a month. That's less than the cost of one issue of your favorite woodworking magazine.
SHOP NOTES:
This was supposed to be the mid-week follow-up to last weekend's video on routing the edges of small circles. If you missed it, be sure to catch it here: https://youtu.be/zPKVNuLsb6g
🟢 This is the tape that I was recommending for pad-sawing and for temporary jigs and fixtures: https://amzn.to/2UmFno2
🔴 This video was made possible by the generous support of the 100+ "MGR" channel members. To learn more about the perks of channel membership, check this out: https://www.youtube.com/channel/UCGsm...
A few viewers have requested I provide affiliate links to help them find the products I use and as a way of supporting the channel through commission. If you purchase a product or service with the links I provide, there is no additional charge to you. I always recommend shopping around for a better price. Thank you for supporting My Growth Rings!
