SHOP NOTES: As promised here's how I change abrasive discs on the Shopsmith conical sanding disc and how to modify stock abrasive discs to work on your Shopsmith conical disc. I purchased this disc used on eBay and the paper was old and crusty and just didn't want to let go, so heat and solvents were needed. If you swap the abrasives before the adhesive gets old and cured you'll stand a much better chance of a clean removal. There's bound to be a prayer that helps, too.
Please consider joining the 100+ other channel members in supporting the channel and get access to perks:
https://www.youtube.com/c/MyGrowthRings/featured
Here's an idea: If you aren't ready or able to join the channel, you can always support the channel by watching, clicking the thumbs-up, commenting, sharing, and by clicking through the provided links whenever you are shopping on Amazon or eBay. You don't even need to purchase the items these links lead to, but by going through these links they'll reward us with a small "finders fee". Thanks in advance for the support!
I've created an Amazon list of many of the tools that I have found to be indispensable in my shop.
http://a.co/0GLhuR2 You may have to click the "Filter" link to show the items in the list. I suggest sorting them by priority.
Here are links to a few of the products I used or discussed in this video:
A handy 30 piece set of assorted 12" sanding discs:
https://amzn.to/3nDlZPr
A pair of 12" 220 Grit discs for sharpening with the conical sander (You'll have to modify the discs as I did in the video:
https://amzn.to/3CzNf5r
Here's the circle cutter I used to cut the hole in the abrasive disc. Remember to cut from the back only!
https://amzn.to/3xapa4e If you'd prefer the premium Olfa version, find it here:
https://amzn.to/3HTxhr1
Here's the current product page for the Shopsmith conical sanding disc:
https://www.shopsmith.com/ownersite/c...
Visit
http://www.MyGrowthRings.com
Follow on Instagram @MyGrowthRings
I also blog at
http://www.tool-hunter.com/shopsmith-posts and
http://shopsmith-tool-hunter.blogspot.com/
A few viewers have requested I provide affiliate links to help them find the products I use and as a way of supporting the channel through commission. If you purchase a product or service with the links I provide, there is no additional charge to you. I always recommend shopping around for a better price. Thank you for supporting My Growth Rings! Scott
#ChangingSandingDiscs #ShopsmithConicalSander #DIYConicalSanderDiscs
