SHOP NOTES: Every 25 hours of run-time your Shopsmith Mark V's headstock needs to be oiled in two places. This can be done with the headstock on the machine, but to make this a little easier to film and to show how easy it really is to remove for more in-depth maintenance, we'll go ahead and pull the headstock off. While it's off we'll pull the V-Belt, just to show how easy that is, for the day when you'll eventually need to replace yours.
0:00 - Intro
0:45 - Sealed ball bearings in a Shopsmith Mark V headstock
2:02 - Why we add oil to the Shopsmith headstock
2:21 - 3 tips before you remove the Shopsmith headstock
3:18 - How to remove a Shopsmith headstock
4:51 - Removing the belt cover and quill feed lever
6:39 - Oiling the (Speed) Control Sheave
8:57 Removing the V-Belt
10:16 - Oiling the Floating Sheave
12:44 - What I forgot
13:48 - Final words (Don't miss these!)
Products used in this video (in no particular order):
Visit http://www.MyGrowthRings.com
Follow on Instagram @MyGrowthRings
I also blog at http://www.tool-hunter.com/shopsmith-posts and http://shopsmith-tool-hunter.blogspot.com/
DISCLAIMER:
A few viewers have requested I provide affiliate links to help them find the products I use and as a way of supporting the channel through commission. For example, as an Amazon Associate, I earn from qualifying purchases made through the links I provide. If you purchase a product or service through these links, there is NO additional charge to you. I always recommend shopping around for a better price. Thank you for supporting My Growth Rings!
#ShopsmithMaintainance #ShopsmithHeadstock #Shopsmith
