gospelman.1
gospelman.1
- Bronze Member
gospelman.1
I was wondering if you could use other saw blades or dado tools from other saws on the shopsmith? An how if you can?
Yes, Shopsmith makes 5/8" arbors in both the MKV 500 (555321)and 510/520 (555608) versions for saw blades with a 5/8" arbor hole.
For the dado you use the Dado/Molder Arbor (555506). You would also need the Dado Table Insert, ((505621) for the MKV 500, or the (555120) insert for the 510/520. For the Shopsmith, or any saw 2 HP or less, the 6" dado is preferred.
Welcome, and come back often.
- woodburner
Or 9" if using a certain older model with an 'extra' blade slot.woodburner wrote:And don't forget that the saw blades should not exceed 10-inches.
