I have an older (cast iron table) bandsaw, which is seemingly in near new condition. My only complaint was the gosh awful squealing from the 3 roller guide bushings. Each session where I used the saw I would have to hit the guides with a shot of spray oil, which then collected sawdust. Something I hated.
Anyhow, SS just put their retro kit (555074) on sale for $18 and change. All I can say is WOW!!!!! My bandsaw has never sounded so good!
The kit is well worth the money and is super easy to put on. It essentially is just sealed bearings and new bolts that replace the old bushings (which look like somewhat like bearings but are not). I understand that the bearings do wear out after reading other posts, but I can live with that and will just consider them "consumable" parts.
If you have the cast iron table bandsaw, get this kit. It is well worth the money, even at regular price.
Bandsaw Bearing Retro-Kit
Good to hear (read), Otee!!:)
P.S. Welcome to the Forum - If your Dad is jealous, maybe you'll let him use the bandsaw? BTW, What part of the world do you call home? You can put it in your signature block in your profile.
Thats 555074?otee453 wrote:I have an older (cast iron table) bandsaw, which is seemingly in near new condition. My only complaint was the gosh awful squealing from the 3 roller guide bushings. Each session where I used the saw I would have to hit the guides with a shot of spray oil, which then collected sawdust. Something I hated.
Anyhow, SS just put their retro kit (55074) on sale for $18 and change. All I can say is WOW!!!!! My bandsaw has never sounded so good!
- toolcollector
- Silver Member
Good to here the bearings are such an improvement, as I just ordered them also. Also ordered the urethane tires as the tire on my idler wheel came off - the rubber was cracking and old. Unfortunately, the tires are apparently on backorder, so my band saw is out-of-service until whenever.
'83 500/520, '54 500 Greenie, Shopsmith Power Station, Planner, Jointer, Belt Sander, Strip Sander, Scroll Saw, Bandsaw, Jigsaw, Lathe Duplicator, Router Table, Dust Collector & Dewalt Dual Compound Sliding Miter Saw.
