1" CBN wheel adapter?
Arrowx
Post by Arrowx »
I have a new 6" CBN wheel that I need to attach to my bench grinder. My problem is that the grinder arbor is 1/2". I have found arbor sleeve adaptors to reduce to 1/2". Is that a smart idea with CBN wheels?
Thanks!
Re: 1" CBN wheel adapter?
I think that should be OK but you might want a more precise sleeve than the run of the mill ones. For instance, CBN wheels are very heavy compared to other wheels. A cheap plastic sleeve would not be appropriate in my opinion.
I would contact Wood Turners Wonders at https://woodturnerswonders.com/. They sell a huge variety of CBN wheels and the owner is very knowledgeable and forth cumming with good advice.
Arrowx
Post by Arrowx »
Thank you for the quick reply. The idea of plastic sleeves made me nervous but I wondered about metal ones. I will certainly check out the business you suggested
