Carter guides
Gene Howe
Carter guides
Post by Gene Howe »
What's everyone's opinion on these guides as opposed to cool blocks or wood?
I do a lot of re-sawing and a lot of work with a 1/8" blade. I like capturing the small blades in the blocks. Just wondering if the Carter retrofit would give the same amount of support.
Thanks.
Gene
beeg
Post by beeg »
I've read here that people are happier with the ceramic blocks for the bandsaw. Our own Bill Mayo sells them for a total of $16.50.
"I have almost any Shopsmith part/item available for sale it you have any Shopsmith wants or needs."
Bill http://www.billstoolz.com
ldh
Post by ldh »
Gene,
I have the Carter Guides on one of my SS bandsaws and they work great, but I would not use them with a blade under ¼". I also use the ceramic guides and they work just as well as the Carter Guides with the same restrictions. When you use blades under ¼" the Cool Blocks are the only way to go.
ldh
Gene Howe
Post by Gene Howe »
Thanks everyone for the info.
Gene
Hi,
If you look along the top you will find a search function, if you put carter guides in the box you will find what else has been said about them. This is one has a picture and a bit more information:
http://www.shopsmith.net/forums/showthr ... ter+guides
But feel free to check out some of the other threads.
Gene Howe
Post by Gene Howe »
Thanks Ed. I did as you suggested. I think I'll stick with my homemade teak guides for the small blades and order some ceramic guides from Bill...maybe.
Gene
