Good day, I have two marks V and one 10er, where can i get the table and the table support for my 10er
Jacques
I am from Canada
10er table and table assembly
- Bronze Member
Re: 10er table and table assembly
Since the Shopsmith Model 10ER was last made in 1953 OEM parts must be found elsewhere. Common hardware is easy to find and 2 parts from the Model 10's are still used on the Mark series tools today. For the Table parts check at online auctions or your local craigslist or similar. This applies to both the Main and Extension Tables. The Owner's Guide (manual) can help you identify the parts you need.
All SPT's & 2 Power Stations
The most economical way to get parts for a 10ER is to locate one locally. It is usually cheaper to find a complete unit than to buy parts separately, and you will get a bunch of bonus parts as well. It can be handy to have multiple arbors, sanding disks, drill chucks, etc.
