Everything was complete, clean with no scuff marks or signs of wear (except the pulley at the top). Even the 1995 Instruction Manual and the miter gage. I did some disassembly to blow out ancient dust and wipe things down. “I’ll let you have it for $20.”
This is a Model 31-080 1” Belt / 5” Disc Sander. Now I need to know what belts to get for it that are good quality. I bought some sandpaper from Lee Valley a few years ago and it is very good. Every recommendation on the internet seems to be ad driven now so I don’t trust any of that.
The Lady Made an Offer I Couldn’t Refuse
- 1.JPG (17.76 KiB) Viewed 1439 times
- 2.JPG (11.41 KiB) Viewed 1439 times
- 3.JPG (12.88 KiB) Viewed 1439 times
- 4.JPG (11.68 KiB) Viewed 1439 times
- 5.JPG (12.17 KiB) Viewed 1439 times
- Note slight abrasion on the right side of the pulley.
- 6.JPG (14.19 KiB) Viewed 1439 times
Re: The Lady Made an Offer I Couldn’t Refuse
David,
I bought the harbor freight copy of that sander many years ago. The HF sanding belts have worked fine for me, here's an aluminum zirconia belt as an example, looks like it's stocked at all the OKC area stores; https://www.harborfreight.com/1-in-x-30 ... 60424.html. If you want a wider selection of grits, you might look at Klingspor; https://www.woodworkingshop.com/abrasiv ... 0X%2030%22.
Roy
Home designed and built CNC router, another CNC router
desktop size, Avid 5x10 Pro CNC w/ATC, CNCed G0704 milling machine
Laser engraver
Way too much other stuff and not enough space
Laser engraver
