Arm / Base - Rollpin removal
I'm restoring a 1953 Greenie and I would like to remove the Arm Base. The shaft that holds the Arm Base to the Base is held in place with what looks like a 1/8" rollpin which is driven into blind hold. Any tricks to removing the rollpin. The rollpin appears to be hardened and is difficult to drill out.
Dave - Idaho
"Why do we drive on parkways and park on driveways?"
The roll pin can be driven straight into the base and will fall down inside the base. I find that you need a pin punch the size of the roll pin. Make sure the punch being used is flat on the end so you do not expand the roll pin as it is being driven out. The roll pin is case harden steel and normally cannot be drilled using regular steel bits.
bucksaw wrote:I'm restoring a 1953 Greenie and I would like to remove the Arm Base. The shaft that holds the Arm Base to the Base is held in place with what looks like a 1/8" rollpin which is driven into blind hold. Any tricks to removing the rollpin. The rollpin appears to be hardened and is difficult to drill out.
judaspre1982
Re: Arm / Base - Rollpin removal
Yes. Thank the owners of old school message boards.
Now I can keep on working.
THANKS
THANKS
