Shopsmith Christmas catalog
I got my Shopsmith Christmas catalog in the mail yesterday. Interesting to note that they are now carrying the Excalibur scroll saw.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
1998 bandsaw
2016 beltsander
jointer
overarm pin router
- rlkeeney
Re: Shopsmith Christmas catalog
The new Excalibur scroll saws are made in China and have issues.
I'm currently in the market for a new scroll saw. The one at the top of my list is Pegas.
Robert Keeney
Tallahassee Florida
#odinstoyfactory
Robert Keeney
Tallahassee Florida
#odinstoyfactory
Robert,
Interesting. I didn't realize that Excalibur had moved their manufacturing. Below is some more info on it and why their saws manufactured in China are not as good. Thanks for pointing this out. I believe Pegas saws are manufactured in Taiwan so they should definitely be an improvement.
Excerpt from: https://forum.scrollsawer.com/forum/scr ... libur-saws
"When Excalibur moved from Canada to Taiwan, they brought the tooling with them and engineers helped them set everything up. That's why the saws coming from Taiwan were the same quality as the saws coming from Canada. When they moved to China, they had none of that."
RF Guy
- rlkeeney
Seyco is also a good choice if you don't need to tilt to 45 degrees. Making bowls you might need this.
Seyco's support is top-notch. I just got off the phone with Ray Seymore ( the owner ) getting a bit of tech support for a broken saw. They carry parts for their Seyco saw, Excalibur and Pegas. If you have one of the Chinese saws they can help you with that too.
https://www.seyco.com/
Robert Keeney
Tallahassee Florida
#odinstoyfactory
Robert Keeney
Tallahassee Florida
#odinstoyfactory
I just got a new old stock 2007 Excalibur scroll saw. From my research, the Jet, Pegas and Seyco are made in the same factory in Taiwan that used to make the Excalibur.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
1998 bandsaw
2016 beltsander
jointer
overarm pin router
- rlkeeney
That sounds right. Some of the features on the Seyco are different but the guts are pretty much the same. The Jet has some issues with the blade clamps that should be looked into if you are considering buying a Jet.thunderbirdbat wrote: ↑Mon Oct 31, 2022 10:46 am I just got a new old stock 2007 Excalibur scroll saw. From my research, the Jet, Pegas and Seyco are made in the same factory in Taiwan that used to make the Excalibur.
Robert Keeney
Tallahassee Florida
#odinstoyfactory
Robert Keeney
Tallahassee Florida
#odinstoyfactory
I was considering the Jet before I found the NOS Excalibur. Pegas makes aftermarket blade clamps for at least the Jet, Excalibur, DeWalt, and Seyco. From what I understand you can replace either just the problem bottom clamp on the Jet or both.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
1998 bandsaw
2016 beltsander
jointer
overarm pin router
- rlkeeney
I have Pegas clamps on my EX21. I highly recommend them. You can buy them at https://www.artcraftersonline.com/. Art Crafters is also a good place to buy blades. I have purchased about ten gross from Denny.thunderbirdbat wrote: ↑Mon Oct 31, 2022 12:11 pm Pegas makes aftermarket blade clamps for at least the Jet, Excalibur, DeWalt, and Seyco. From what I understand you can replace either just the problem bottom clamp on the Jet or both.
Robert Keeney
Tallahassee Florida
#odinstoyfactory
Robert Keeney
Tallahassee Florida
#odinstoyfactory
