Jigsaw blades
ChrisHan
Jigsaw blades
Post by ChrisHan »
Hey guys
Looking for any and all information on jigsaw compatible blades. Jigsaw...not scrollsaw.
Thanks in advance
Re: Jigsaw blades
Any 5" will do. Pins can be removed from coping saw blades.
Re: Jigsaw blades
JPG wrote: Mon Dec 19, 2022 11:31 pm Any 5" will do. Pins can be removed from coping saw blades.
Not "any" 5", coping saw blades. My coping saw blades have loops not pins.
Re: Jigsaw blades
My new thing learned fer today!
Re: Jigsaw blades
Because the Jig Saw is designed differently than the Scroll Saw it cannot use blades designed to cut in both the up and down stroke like a Scroll Saw can. You should only use blades designed to cut in a single direction which for the Jig Saw is the down stroke. The finer the blade the more easily it can be bent in a Jig Saw so use caution.
All SPT's & 2 Power Stations
