I'm playing with Sketchup and was wondering how to get small surface measurements to be readable. For instance, when dimensioning a 2" surface, the 2" is sandwiched between the lines and is unreadable unless I really zoom in on it. Is there a way to get the 2" to read outside the dimension lines?
Brent
Sketchup Dimensioning
Sketh-up Dimensions
Go here
http://www.sketchupforwoodworkers.com/
And check out all the sketch-up how-tos. He is really a good teacher.
P.
P.
Serial #12-21-93 - 510 with Bandsaw and 4" Jointer:)
Greenie with Jointer and Jigsaw:D
Yes, you can relocate the text.tnerb wrote:I'm playing with Sketchup and was wondering how to get small surface measurements to be readable. For instance, when dimensioning a 2" surface, the 2" is sandwiched between the lines and is unreadable unless I really zoom in on it. Is there a way to get the 2" to read outside the dimension lines?
Brent
Point at the text and right click. A drop down menu occurs. Select "Text Position". Three positions are displayed. The one that is checked is active. Select the one you want.
THANKS Dusty:) Thanks tnerb:)dusty wrote:Yes, you can relocate the text.
Good Night 'John Boy'.tnerb wrote:Thanks Dusty.......
