Operates Shopsmith on a GFCI circuit?
DLB
Post by DLB »
KyleWalker wrote: Wed Aug 30, 2023 10:55 pm Is there anyone in this group who operates their Shopsmith on a GFCI circuit? If you do, have you encountered issues with it tripping frequently? On a related note, does anyone here run their dust collector on a GFCI circuit? How has that experience been? I've come across several instances where people with equipment featuring substantial motors have faced challenges with GFCI trips, and I'd appreciate hearing your insights on this matter.
I've run both on GFCI without issues. Shopsmith recommends a GFCI circuit breaker rather than outlet for PowerPro, but mine run fine on a regular GFCI outlet. GFCI for garage outlet receptacles has been standard for a long time, over 40 years IIRC.
twistsol
Re: Operates Shopsmith on a GFCI circuit?
Post by twistsol »
I finished my basement where my shop is in 2021 and while it wasn't code yet, the inspector strongly recommended I use GFCI/AFCI breakers for all the basement outlets. I've never had an issue tripping on either of my 520's. All the 120v outlets in the shop are 20 amp.
My dust collector is 220v 30 amp and it is on a GFCI as well and no issues there either.
Thanks much,
Chris Phelps
Cheap tools are too expensive
2x Mark 5 520 and a 10ER
Mike907
Post by Mike907 »
I have GFCI outlets in my garage. Neither the standard headstock nor the PowerPro tripped the GFCI, but I have a variable speed lathe that did. I switched the outlet to a hospital grade GFCI and that solved the problem.
twistsol wrote: Thu Aug 31, 2023 5:28 pm My dust collector is 220v 30 amp ...
What's the horsepower rating on that beast?
twistsol
Post by twistsol »
BuckeyeDennis wrote: Fri Sep 01, 2023 7:46 am
It is a Jet JCDC3 3 HP. It requires a 20 amp circuit but I didn't want to be limited if I ever need to replace it. In my 1000 square foot shop, it is plenty along with 3 HEPA vacs for bench top tools.
Thanks much,
Chris Phelps
I would not expect a tripping problem with a 240v load due to noise filter capacitors creating unbalanced line leakage currents.
When one of those lines is neutral(120v) the filter capacitors will create a small unbalanced current.
