Hi,
Over the weekend I did a 500 to 510/520 hub conversion for one of my disk sander. This was the last one so all of my disk sanders are updated! (I have a total of 5, one with velcro, one for sharpening, and 3 with different grits)
I'm also trying to clean up a little and this is hard as I hate to throw out stuff but for the life of me I can't think of any good uses for the old shorter hubs. Since I had no luck getting the screws out (I just drilled the heads off) so I would have to deal with getting the old screws out to reused them....
Anyone found any use for these? Right now I'm thinking take out the setscrew and recycle the hub???
old disk sander hubs
I cut some disks from 1/4" hardboard drilled a center hole and attached them to my old hubs. I then glued on some red, grey and white nylon buffing pads to make disk buffers. You could attach leather and make a disk strop, etc. Additionally, you could attach a reasonably thick wood disk and make a disposable lathe plate. Just glue on a bowl blank (newspaper in between) and turn.
Dave Hall
Dave Hall
