I'm hoping I wasn't seeing something Photoshopped.....
I saw a pic of a 10ER with what looked like a machinist vise on the shaft. I can think of a lot of uses if that's the case. Is there such a thing and has anyone done it?
Kevin
Vise
Re: Vise
Yes I have two. However it requires the use of a faceplate to mount to the SS quill.
Are you sure it was not a wood working chuck? They do look similar, but are far lighter than the machinist variety.
Real1shepperd
Re: Vise
I'm not sure at all. It looked like a machinist vise, but I could be wrong. I'm not gonna do any metal machining with the 10ER, but would like to be able to clamp larger metal-shaped things so I can spin & polish them.
Do you have any pics of what you have?
Kevin
Kevin
Real1shepperd
Re: Vise
Wrong terminology. What I want is an independent four-jaw *chuck*....around 6" in diameter as it turns out. I finally got ahold of Skip and he's planning to have these on his site at some point. In the interim, he gave me some company names to get the adapter and the chuck I needed.
If I'm successful with this and it all works without modification, I'll give further info if anyone is interested.
Kevin
Kevin
