Riving Knife
ArtTrek
Riving Knife
Post by ArtTrek »
Just bought a new Mark 7...
Setting up the table saw, I cannot get the riving knife centered over the blade. It's about 1/2 over the blade. Are there any adjustments? Can't find anything in the manual...
Matanuska
Re: Riving Knife
Post by Matanuska »
1/2” horizontally or vertically? The knife on the saw guard or the stand alone knife?
- Matanuska
1984 Mark V upgraded to 520 PowerPro. Shopsmith cast iron table bandsaw, jointer, belt sander, and 60's vintage 610 jigsaw SPT's. Makita 2040 15" planer, JessEm Mast-R-Lift II router table.
ArtTrek
Re: Riving Knife
Post by ArtTrek »
1/2 the blade width, horizontally...
Was that way with the saw guard, which came new... it appeared to be bent. I ordered a new one. Prior to attaching the saw guard, I checked the new one. It was still half the blade width off, horizontally. About 1/16"
twistsol
Re: Riving Knife
Post by twistsol »
If I understand the issue correctly, check out this link below. I had the same issue with mine, i believe.
viewtopic.php?t=17715&start=20
Thanks much,
Chris Phelps
Cheap tools are too expensive
2x Mark 5 520 and a 10ER
DLB
Re: Riving Knife
Post by DLB »
ArtTrek wrote: Wed Jun 05, 2024 8:09 pm Just bought a new Mark 7...
There is a screw in the lower saw guard that adjusts/sets the spacing of the position of the guard relative to the quill. (And therefore position of the riving knife relative to the blade.) The screw has a flat head and the usual 5/32" drive, it is immediately below the hole that the quill goes in. This should be in the M7 manual, it is for the 510/520 (IIRC).
HopefulSSer
Re: Riving Knife
Post by HopefulSSer »
Twistsol's link shows it, as does this one from dusty:
viewtopic.php?t=19175
Mark V 510 51-014654
Matanuska
Re: Riving Knife
Post by Matanuska »
ArtTrek wrote: Wed Jun 05, 2024 9:05 pm 1/2 the blade width, horizontally...
The adjusting screw others have mentioned will help but since it only contacts the lower saw guard on one side of the quill it can cause the guard to get cocked out of square when you mount it on the quill. I lived with that for awhile and then just put a ring of appropriate thickness gasket material on the quill that I push the guard up against when I install it. That works much better for me than using the offset screw.
- Matanuska
ArtTrek
Re: Riving Knife
Post by ArtTrek »
The set screw suggestion works perfectly... it provides are subtle adjustment. Thanks for your help!!!
Art
