Powerstation issue
rsefczek
Powerstation issue
Post by rsefczek »
Recently moved and went to use my power station but the motor hums without actually turning. The belts appear intact. Any suggestions for troubleshooting?
Re: Powerstation issue
Suspect start switch.(internal)
Allowing it to hum without turning (even for a short while) can do terminal damage to the motor,
I suggest getting into the hands of someone who knows motors.
DLB
Post by DLB »
First step for me is remove the motor belt and try again. Briefly, as Dusty says. The idea here is to isolate between an internal motor problem and a mechanical load problem. Alternatively, if it is reasonably easy to turn the spindle with your hand this also points to a motor problem.
rsefczek
Post by rsefczek »
Thanks for the suggestions. The spindle does turn easily so probably the motor. I was afraid the movers may have done something since they managed to shear the casters off the base. Gotta love moving….
