ZCI material
- stihlsawer
ZCI material
Looking at making a few ZCIs. Anyone use lauan plywood? What are you all using?
Trever
SS 510 dated 10 November 1995
- stihlsawer
Re: ZCI material
I had a ZCI insert made from luan plywood for my first machine, a 500. Not sure what happened to it, might still have it somewhere. Worked OK. If I had to make another one I was considering PVC sheet but then noticed HDPE sheets available on Amazon. Not sure how well either one cuts when a blade is forced up through them.
Polyvinyl Chloride and High Density Polyethylene. My apologies
- stihlsawer
Re: ZCI material
Thank you Ed. I'll give it a shot when I get a chance and report on it. I hadn't thought of PVC sheet.
Trever
- edflorence
Re: ZCI material
Tempered hardboard works great for zci's. Rough out the shape on the bandsaw, then use drum sander and pattern sanding set-up in drill press mode to get the finished shape. You can cut out a batch of them pretty quickly. Its good to have one for the different frequently used table tilts, like 15, 30, 45, as well as one for the zero tilt and a couple of blanks for the unusual angles.
Idaho Panhandle
Idaho Panhandle
- stihlsawer
Re: ZCI material
Thanks you for the tip. Hardboard would work well. I look forward to getting my 5q0 up and going. Still cleaning when time permits and waxing.
Trever
- BuckeyeDennis
Re: ZCI material
In my experience, the veneer on Lauan plywood is very splintery. But it’s darned good-looking stuff for the price.
I made a ZCI from a scrap of 1/2 Baltic Birch plywood a few years ago. That stuff machines beautifully, and so far I’ve had no need to replace it.
- stihlsawer
Re: ZCI material
Nice!! I'm contemplating maple ply as well. I think if I do use the lauan ply, I will use tape to help with splittering.
Trever
Re: ZCI material
1/2????BuckeyeDennis wrote: Fri Nov 08, 2024 9:28 pm In my experience, the veneer on Lauan plywood is very splintery. But it’s darned good-looking stuff for the price.
- BuckeyeDennis
Re: ZCI material
Ok, 12 mm. I rabbet around the bottom perimeter so that the top surface is flush with the table. The extra material remaining in the middle keeps it nice and stiff.JPG wrote: Sun Nov 10, 2024 9:37 pm1/2????BuckeyeDennis wrote: Fri Nov 08, 2024 9:28 pm In my experience, the veneer on Lauan plywood is very splintery. But it’s darned good-looking stuff for the price.
The slot fits either the blade guard or the non-through riving knife.
