Has anyone found a source for Shopsmith compatible miter bars that fit an Incra Miter 5000 or would be willing to part with a pair?
I am looking for:
1 - PM5K-700200 M5 Steel Miter Bar w/Expansion Disks (Shopsmith)
1 - PM5K-700300 Aluminum Miter Bar, 18” (Shopsmith)
Terry
Incra Miter 5000 (Shopsmith runners)
Re: Incra Miter 5000 (Shopsmith runners)
I would suggest you contact incra directly. It is possible they have some old Shopsmith stock they can't be bothered to put on the website, and if enough people call and ask for the part, they might consider producing a limited run of them!
Geoff Baker
1951 10ER w variable speed electronic motor with reverse
1999 520 w PowerPro
Belt sander - strip sander - bandsaw - scrollsaw - jointer - overarm router - undertable router mounted on main SS saw table - speed increaser - speed reducer - forced air HEPA filter for headstock - 19" SS powered aluminum drum sander - index wheel system - lathe table crossslide vise system
1999 520 w PowerPro
- twistsol
Here are the pictures of the PM5K-700200 M5 Steel Miter Bar w/Expansion Disks (Shopsmith) as promised in my PM. As noted, I was unable to locate the other part.
This is the overall bar, the total length including the T-slot tab is 26" Here is the end that attaches to the miter gauge of the Miter 5000 there is a little scratching from the washer There are some scratches on the back side of it. I don't know if these were there when I used it or happened in the intervening years that it sat in a drawer in the shop Finally, you can see a bit of wear on the expansion disks where they rode in the miter slot.
Thanks much,
Chris Phelps
Cheap tools are too expensive
2x Mark 5 520 and a 10ER
Chris Phelps
