humming
sawchain
humming
Post by sawchain »
Just to let beverone know, my shopsmith is down. The repair shop said that my motor is burned up. So I have to look for a replacement motor.:mad: So thanks for all the info, tried all of them!!!!!! Fred
My condolences; I do hope that recovery comes soon and without great pain.
billmayo
Shopsmith Headstock Motors
Post by billmayo »
sawchain wrote:Just to let beverone know, my shopsmith is down. The repair shop said that my motor is burned up. So I have to look for a replacement motor.:mad: So thanks for all the info, tried all of them!!!!!! Fred
All Shopsmith headstock motors, 3/4 HP and 1 1/8 HP are interchangable and will bolt to the motor pan. The floating sheave, washer/snap ring or nut and spring are different on rhe earlier 3/4 HP motors than on the 1 1/8 HP motors. The floating sheave from the 1 1/8 HP motor has a longer shaft body and will prevent the floating sheave from fully opening at lower speeds when used on the earlier 3/4 HP motors. When buying a used motor, always try to get the fan and floating sheave along with the spring and nut or washer/snap ring included. Ebay normally has motors for sale.
neaptide
humming...
Post by neaptide »
Turned mine on the other day and it just hummed at me.
Went to this site and gave it a good think...
Took off the motor and brought it into a rather shabby electrical shop and the man in charge took a look at it and then a closer look and stuck a screwdriver in the vent hole and I heard a click. He said "Ha Ha! 5 bucks please!"
He plugged it in and it worked. He said to keep it cleaner next time. Contact switch was stuck.
I walked out smiling.
mbcabinetmaker
Post by mbcabinetmaker »
neaptide
Welcome to the forum. I am glad you were smiling and hope you were humming on your way out.
Thanks for joining
Mark
sawchain
humming
Post by sawchain »
Just to let everyone know, I'm back in action. I bought a used motor on e-bay for $85.00 plus shipping. I cleaned the motor and lube before I put it in, fit like a glove.:) :) Fred
mbcabinetmaker
Sawchain
Glad you are back in business!
Mark
mbcabinetmaker wrote:Sawchain
Mark
Mark: WHAT is your Avatar now???:confused:
