Hardboard molding head table insert?
- easterngray
I intend to make a molding head table insert from hardboard for my 500 - does anyone see an issue with this? Just want to make sure I'm not overlooking anything - Thanks - Alec
- a1gutterman
Hi Alec,easterngray wrote:I intend to make a molding head table insert from hardboard for my 500 - does anyone see an issue with this? Just want to make sure I'm not overlooking anything - Thanks - Alec
I can knot think of a reason knot to. Pretty much any material will work as long as you can machine it to fit the table and a slot for the molder head.
Tim
- easterngray
Lower that table down on the revolving blade very slowly. I have had hard board break near the screw holes and I have decided it was because I was lower onto the blade too aggressively.easterngray wrote:Thanks Tim - That's what I figured. I have made a zero clearence insert from 1/4" hardboard and it worked just fine, so I figure a molding insert will too - thanks - Alec
I just made a dozen blanks and cut three of them with no problem.[ATTACH]4637[/ATTACH]
- ZCI.png (51.58 KiB) Viewed 4543 times
dusty wrote:Lower that table down on the revolving blade very slowly. I have had hard board break near the screw holes and I have decided it was because I was lower onto the blade too aggressively.
DUSTY!!!!! He has an early GOLDIE!;) Inserts are DIFFERENT!!:(
- easterngray
Dusty's drawing is good for 505/510/520 tables(in case you should get used table and carriage elsewhere).easterngray wrote:That's alright - thanks for the drawing just the same - I like it and made a copy so that when my dream comes true and I own an anniversary model 520 I'll have it at hand!Alec
BTW DUSTY I DO like your method of dimensioning from a common edge. Makes it easier to layout.
