quill moves when extended. is is worn?
tprowood
Post by tprowood »
I have a Mark V. When I drill on hardwood i notice that the bit wanders when it contacts the wood. I'm using speeds recommended for the drill bit size in the manual. I've checked the chuck and knurled collar set screws are tight. And the set screw in the Headstock for the quill is set just loose enough for the quill to move freely.
Do I have worn out parts? Is there some other adjustments I need to make?
edma194
Re: quill moves when extended. is is worn?
Post by edma194 »
How old? The older versions had a single bearing quill with more runout. How old an what type of chuck? Sometimes that's the problem.
Quill deflecting or bit deflecting? What size bit?
tprowood
Post by tprowood »
It's a early 1980s with original parts and chuck. It feels like the chuck has play in it. More pronounced when I'm using 3/8 and larger bits.
Matanuska
Post by Matanuska »
What kind of bit? Twist drills can wander on growth ring hardness differences where bradpoint won’t.
- Matanuska
1984 Mark V upgraded to 520 PowerPro. Shopsmith cast iron table bandsaw, jointer, belt sander, and 60's vintage 610 jigsaw SPT's. Makita 2040 15" planer, JessEm Mast-R-Lift II router table.
Are you drilling a pilot hole before drilling with larger bits?
GetterDone
Post by GetterDone »
As already mentioned,
A twist drill will wander and as the Diameter increases it gets worse.
Yes, the Quill may have some wear.
I suggest some HSS center drills.
Link: https://www.amazon.com/Metalworking-Com ... B0DLGVWZBL
Give these a try and see if that improves your drilling.
The biggest size of this set may bottom out in your chuck before setting secure on all three jaws.
Just something to be aware of.
There are also single end center drills .
Dwayne
tprowood
Post by tprowood »
I hadn't thought about a pilot hole, guess I have lots to learn. I'll see if that helps. Or, try some center bits. Thanks.
