Bearing removal & installation
Matanuska
Post by Matanuska »
The bearings in the Ridgid R2900 2.25 HP router I have installed in my router table have started to squeal and I need to replace them. I can handle pulling the old ones but I don't have a bearing press & wondered if anyone has any tips for ways to install the new bearings without a press.
- Matanuska
1984 Mark V upgraded to 520 PowerPro. Shopsmith cast iron table bandsaw, jointer, belt sander, and 60's vintage 610 jigsaw SPT's. Makita 2040 15" planer, JessEm Mast-R-Lift II router table.
Re: Bearing removal & installation
Matanuska
Post by Matanuska »
That will pull them. I need to figure out how to press on the new ones.
- Matanuska
It will pull them ON as well as OFF. It applies pressure to the inner race hub only.
Matanuska
Post by Matanuska »
OK, sounds promising. How would you set it up to pull a bearing onto the end of a shaft or into a hole?
- Matanuska
Matanuska
Re: Bearing removal & installation - UPDATE
Post by Matanuska »
Good news - I don't have to worry about replacing the failed bearings on the Ridgid router in my router table. Before ordering the bearings I called Ridgid's customer support line and was pleasantly surprised to find out that bearing failure is covered under the lifetime warranty I activated 17 years ago by registering my router within 90 days of purchase. Even better, since the repair parts are no longer available, they are sending me a brand new upgraded router. Made my day!
- Matanuska
