Turning ideas
Turning ideas
After breaking down an 80’s vintage baby crib that my daughter says no longer meets current safety standards for drop sides and spindle spacing I now have an abundance of hard maple dowels both 1” smooth as well as turned shaped spindles. Any project ideas? Pen blanks come to mind for the 1” smooth dowels but I haven’t turned any pens & wondered if maple is a good fit. Also not sure what to do with the shaped spindles - they like the smooth dowels have a dark finish but being shaped would be harder to repurpose.
- Matanuska
1984 Mark V upgraded to 520 PowerPro. Shopsmith cast iron table bandsaw, jointer, belt sander, and 60's vintage 610 jigsaw SPT's. Makita 2040 15" planer, JessEm Mast-R-Lift II router table.
- edflorence
Re: Turning ideas
How long are the dowels? If long enough, use the 1" dowels as legs and turn the shaped ones down for the thin spindles on some footstools. The tops can be caned, woven rope, Shaker tape, or paper rush. Check out some of the Shaker style footstools to get an idea of what I am talking about.
Idaho Panhandle
Idaho Panhandle
Re: Turning ideas
The longest dowels are at least 12” so a footstool is definitely possible. Good idea - I’ll check out Shaker examples.
- Matanuska
- thunderbirdbat
Re: Turning ideas
Maybe use them for a toddler/twin sized headboard and footboard for when the little one gets into a regular style bed. You would have to meet or exceed current spacing requirements but that is doable.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
1998 bandsaw
2016 beltsander
jointer
overarm pin router
Re: Turning ideas
Another good idea, thanks!
- Matanuska
