Help! Parts on the Loose!
ShawnMorton
Post by ShawnMorton »
Howdy. I’m new to the world of Shopsmith but am pretty excited to get going. I recently acquired a Mark V 510 as well as a DC3300. The band saw and jointer were sitting on the frame at the time as well. I was cutting some rabbets today to make shiplap. When I was finished and cleaning up I found two knurled nobs and a bolt on the floor (pictured). The one nob looks like the kind used on the lower saw guard, but both of those are in place and secure. Does anybody have any idea where these may have worked themselves loose from?
Thank you for your time and expertise.
Shawn
ShawnMorton
Re: Help! Parts on the Loose!
Partially solved! The one nut and bolt are the table levelling elements from the bandsaw (a 2 am realization that drove me out to the garage in my pyjamas). The last nob/nut is still a mystery.
ShawnMorton,
You are correct that the Carriage Bolt and the Knurled Nut (in the middle of your picture) is a set used on the Aluminum Bandsaw Table. A similar set is used on the Miter to attach a wood extension to the Protractor face. (Sorry I don't have a picture of that)
_
Blade Path 2006.JPG (306.99 KiB) Viewed 3896 times
As for the other nut (bottom of your picture) the only place I recall using that type is the Lower Saw Blade Guard type below. One of my Lower Saw Blade Guards has the other style Knurled Nut (shown) because I lost one of the original type nuts and replaced both to match.
Another possibility is it may be a stray nut.
_
514358 headstock side.jpg (193.18 KiB) Viewed 3896 times
ShawnMorton
Thanks for the response. I can’t find another place for the second nut to go and it’s reassuring that someone else doesn’t know either. I’m all for the possibility that it was a stray that came out of the boxes of stuff from the previous owner. As there isn’t a nut and bolt on the miter (there wasn’t when I got it), it may well be from there.
Thanks again!
