crosss cut sliding table fence issue
jjsmutney
Post by jjsmutney »
I recently purchased the cross cut sliding table. I am having difficulties installing the fence. It appears that the 2 oblong screw holes which are parallel with the length of the fence should instead be perpendicular . This arrangement of holes limits the fence movement to allow a square cut.
Did anyone have this issue?
Re: crosss cut sliding table fence issue
jjsmutney wrote: Wed Jul 23, 2025 11:01 pm I recently purchased the cross cut sliding table. I am having difficulties installing the fence. It appears that the 2 oblong screw holes which are parallel with the length of the fence should instead be perpendicular . This arrangement of holes limits the fence movement to allow a square cut.
I have not gone to the shop yet to look at my table's hole pattern BUT I believe I would start by mearuring the hole pattern. Is there a set of mounting holes that are in a square pattern?
jjsmutney
Post by jjsmutney »
More info to clarify the situation: the oblong holes are on the fence, running parallel to the length of the fence. This arrangement limits the amount of movement to achieve a fence square to the saw blade.
jjsmutney wrote: Thu Jul 24, 2025 10:14 am More info to clarify the situation: the oblong holes are on the fence, running parallel to the length of the fence. This arrangement limits the amount of movement to achieve a fence square to the saw blade.
Understood. But since I can achieve "square to the blade" without the oblong holes as you describe I cannot subscript to "oblong" being required.
Do not over look the miter bar movement. That also plays into the task of squaring to the blade.
jjsmutney
Post by jjsmutney »
Thanks for the reminder. I'll re-examine the bar.
What do you use to measure fence to blade relation ship? I have a framing square that reliably reports 90.07 degrees.
jjsmutney
Post by jjsmutney »
I use a Crown tool try square from Sheffield, England. Don't have a tool as accurate as your square. Upon re-inspecting my miter bar position, I found it to be off about the amount that I was attempting to correct with the fence. Looks like poor lighting contributed to my error. I now have to adjust the bar.
jjsmutney wrote: Fri Jul 25, 2025 11:07 am I use a Crown tool try square from Sheffield, England. Don't have a tool as accurate as your square. Upon re-inspecting my miter bar position, I found it to be off about the amount that I was attempting to correct with the fence. Looks like poor lighting contributed to my error. I now have to adjust the bar.
I do not consider my framing square to be accurate at all and Crown tools are typically quality items.
jjsmutney
Post by jjsmutney »
Made some adjustments to my saw. My table is now set-up correctly. Had trouble when verifying setup with a test cut - discovered that my Crown try square is not square! Really disappointed! It is not adjustable; just not square. I am now considering spending some money to buy quality - looks like quality may require a "bank loan".
jjsmutney
Post by jjsmutney »
Checked squareness with my drafting triangles.
