Drilling pen blanks
Drilling pen blanks
Anyone have any good ideas on the best way to drill out pen blanks? SS drill press or horizontal configuration? Jigs anyone has come up with to hold the blanks firmly in place ? I've tried a couple of things but still getting some unwanted movement of the blank.
As always, your help is appreciated !
bob
bob
If you wade far enough into this thread you will find considerable discussion in regard to drilling pen blanks. http://www.shopsmith.net/forums/showthr ... +blanks%27
Be careful what you ask for!:D
Major Bob,
Have you tried drilling them like Nick shows in Sawdust Session 8?
http://www.shopsmithacademy.com/SS_Arch ... _Index.htm
Sincerely,
Ron
Sincerely,
Ron
That jig appears to be about what I was looking for, although I would prefer to stay horizontal and avoid the extra effort of tilting up to drill press mode. Looks like you could easily but a 1/4 in piece of sacrificial wood under the blank to protect the jig.
LTC, US Army
Ft. Leonard Wood, MO
Hoo-ah !
LTC, US Army
Hoo-ah !
IMHO I agree with you. Why ould you want to put a square shaped thing in a chuck.major_bob wrote:I guess that expands my question a bit. Should I be considering putting the blank into a chuck and spinning into a stationary bit on the tail stock ?
I'm a novice, but seems like a lot of trouble to drill a hole
I think drilling in horizontal mode with proper clamping makes sense. IF you have a good way to hold them in a drill press vise. that also makes sense.
Necessary to either method is positioning and holding it there.
- tom_k/mo
I'm going to try this method as soon as I get a lathe arbor to mount the Jacobs Chuck to the tailstock.major_bob wrote:I guess that expands my question a bit. Should I be considering putting the blank into a chuck and spinning into a stationary bit on the tail stock ?
I currently drill in Horizontal drill mode, I put the miter gauge extension on the miter gauge and use the adjustable stop on it to hold the block. It works well enough, BUT... you have to keep adjusting the height of the table and the miter gauge position on the table to keep the drill bit in alignment with the center of the blank as not all blanks are the same size. I currently have blanks ranging from 1/2x1/2" to 3/4x3/4" and some that are 1"Dia.
Using a Oneway chuck (or Baracuda chuck in my case) mounted on the quill and a Jacobs Chuck with a stationary drill bit on the tailstock should eliminate all alignment problems. The quill center and the tailstock center are always aligned, so it doesn't matter what size blank I'd chuck up in the headstock chuck, it should automatically be center aligned with the drill bit in the tailstock.
If this works as well as I hope, not only will the holes be centered easily each time, but switching the SS from drilling blanks to turning blanks should be faster, as I won't have to remove/install the table each time, it's just changing the ends on the headstock/tailstock to move from drilling to turning.
I can now see the advantage of chucking the blank, that being, the ability to drill without putting the table top back on.
Unlike many of you with mulitple SS, I only have one (and can't seem to convince the wife of the need for a 2nd) I use the bandsaw for cutting the blanks so putting the table on and off for pen turning really is a pain.
LTC, US Army
Hoo-ah !
LTC, US Army
Hoo-ah !
Also Major Bob. We THANK YOU for your service to our country.
