Sticky Situation...
Sticky Situation...
All,
What type of glue do you use to attach the sandpaper to the Sanding disc?
Is there an option for a velcro backer?
Thanks!
Thanks!
Don Tolbert
Bentonville, AR
10E - sn# R-29399 - 1950
Mark V - sn# 222659 - Dec '87
Bentonville, AR
- curiousgeorge
Hi, Don. Shopsmith does offer a Velcro option as well as a retrofit kit. As for gluing I use 3M spray on glue.
Click here... Velcro Disc
George
Ft. Worth, TX.
Go TCU Froggies
Ft. Worth, TX.
Go TCU Froggies
Let's not forget that sandpaper disks from Shopsmith come with adhesive already on their backs. They are re-usable if heat is applied before removing then the protective (wax?) paper is re-applied to the removed paper.
I store new and used disks in separate paper packages. These are the same packages that contained the disks when purchased from Shopsmith.
I like the Velcro system. For the disc I use for sharpening I like the 3M 77. I am currently using DAP Weldwood Multipurpose Spray Adhesive, which works but if find it messy and not as easy to apply as 3M. Next time I will purchase the more expensive can.
Gary Kalyn
Kalynzoo Productions
Woodworking
Porter Ranch/Northridge
Los Angeles, CA
Woodworking
Los Angeles, CA
Sticky Situation...
Thanks to all for the info. I noticed the adhesive on the disks I have but how do I activate it? it's just shiny. Sorry for the stupid questions, but i just don't know.....
Don Tolbert
Bentonville, AR
Bentonville, AR
It SHOULD have a wax paper covering and it's PSA.
Sticky situation
Just in case you are wondering: PSA = Pressure Sensitive Adhesive. Just peel the (usually) tan backing, carefully apply to disk. Press down firmly. I often turn them over on the concrete and stand on the back side. Not always necessary.
Jim in Bakersfield:D
