Another Belt Sander question
soggysawdust
Post by soggysawdust »
I recently acquired an older belt sander and it has a bit of an odd problem. After setting the tension and then firing it up it continues to tighten the belt. Has anyone ever had this happen before and if so, what is the fix?
Thanks - Phil
beeg
Post by beeg »
Did you clean it up yet?
thainglo
Post by thainglo »
Phil - I had that happen on one a few months back. If I recall correctly, the adjustment bolts were badly misaligned. I was taking the machine apart for a full cleansing and after realigning upon assembly, everything worked fine.
Lost count, over a dozen rebuilt/repaired/restored
Personal equipment: 510 made in 1993, belt sander, jig saw, band saw, planer and jointer
Matt in GA
soggysawdust
Thanks folks, I kind of thought that might be the answer. I guess I will learn how to take it appart and clean it up this weekend.
Phil
soggysawdust
Well, it was nothing more than the adjustment bolts. I think he had adjusted them for non-shopsmith belts. Got them in the proper position and it is working fine now. Thanks for the help.
Phil
soggysawdust wrote:Well, it was nothing more than the adjustment bolts. I think he had adjusted them for non-shopsmith belts. Got them in the proper position and it is working fine now. Thanks for the help.
Phil
HHH HHH HHH (HHH = Hip Hip Hooray!):)
