Ripped boards. They are different widths.
navycop
Post by navycop »
I ripped a 3 1/4" board in half. One half came out 1 1/2". The other half came out 1 3/4". I was thinking about ripping the 1 3/4" down. I didn't know if that would be safe (close to blade). Or can I sand it on the disk sander? Got any plans for a jig or sled I could use?
Mark V 520, Ryobi 12" mitersaw, Delta 10" tablesaw, DC 3300.
beeg
Post by beeg »
Did ya have it set up to rip at 1 1/2"? I'd just rip the other one while it's set up. BUT be careful.
fjimp
Post by fjimp »
navycop wrote:I ripped a 3 1/4" board in half. One half came out 1 1/2". The other half came out 1 3/4". I was thinking about ripping the 1 3/4" down. I didn't know if that would be safe (close to blade). Or can I sand it on the disk sander? Got any plans for a jig or sled I could use?
What tool did you use to rip the boards? Have you measured width on both ends of each board? How about in the middle? Jim
F. Jim Parks
Lakewood, Colorado:)
I would rip down the 1 3/4" piece to 1/1/2" before I would spend any time sanding it. PUSH STICK and FEATHER BOARD are a must if you do this.
But, I would run it through the surface planer to take off that last 1/4".
Sounds like you wanted two boards 1⅝" minus saw kerf. Were you looking for two boards each 1½"? If so you can safely rip the wider board to 1½".
Use your splitter and upper saw guard, use a feather board to hold the wood to the fence, and use a fence straddler for the final several inches of the cut. I would choose a fence straddler rather than a push stick as there is no risk of it coming in contact with the blade. However a push stick will work if held against the fence.
A couple of hints - Please excuse me if I'm sounding too basic.
- Always saw a bit wider than the finished piece to allow for sanding.
- When sawing a board in half always allow for the width of the saw blade (kerf).
a1gutterman
Post by a1gutterman »
navycop,
When you use the featherboard (highly recommended), place it so that it puts preasure against your board ONLY BEFORE the board goes through the blade.
Tim
rdewinter
Post by rdewinter »
navycop
I don't understand how you could rip a 3 1/4" board and end up with a board of 1 3/4" and one of 1 1/2". 1 3/4" plus 1 1/2"= 3 1/4". Where's the kerf?
San Diego
navycop
Post by navycop »
I did have the feather board in front of the blade. I just measured one board after it was cut. I just subtracted 1 3/4" from 3 1/4". The sum was 1 1/2". I didn't think about the kerf. But you get the point. I don't have a planer as dusty suggested. The SS did come with a fence straddler. I guess I can use that.
