Caster Reassembly (A)
This is the first of a series of posts showing A method of reassembling a SS Caster Set.
Who da Thunk??? The Hinge end and the clamp end casters use an identical set of parts! The only difference is the location of the Foot Pedal Crank on the Cam Shaft!
[ATTACH]5592[/ATTACH]
The end castings are the ONLY left right pair. There is one l/r PAIR per caster.
Actual Reassembly Begins with the next link.
This thread is linked to from http://www.shopsmith.net/forums/newthre ... hread&f=10
